Defender Talk about the Land Rover Defender within.
Defender TD5 Clutch Problem - Help needed
Old Apr 2, 2007 | 08:54 AM
cr355's Avatar
Default Defender TD5 Clutch Problem - Help needed
I decided to change the clutch slave cylinder, within half an hour the slave unit was off and ready for the replacement to be fitted. As I tried to pull the rubber push rod seal from the rod the rod itself came detatched from the cluth arm. There is a small plastic clip that slideds on the rod that has 2 prongs which locate round the clutch that prevent the ball on the rod from dislodging out of the socket on the clutch arm. I can't seem to be able to attach it back on - Is there a way of doing this easily or have I caused a recovery to the garage ?
Any help appreciated.
Mitzela
Defender
Oct 10, 2011 03:47 PM
TC.kenya
Jul 10, 2011 08:43 AM
TC.kenya
Defender
Jul 10, 2011 01:56 AM
elvis
Jan 14, 2007 07:46 AM
trini defender
Defender
Dec 11, 2006 05:14 AM
