Defender transfer box oil leak
I have an oil leak from the o-ring on the intermediate shaft of the transfer box situated mid-way between the input and output shafts.
Has anyone changed this o-ring with the transfer box in situ? How do you do it? I have the parts to do the job but am fearful of a bunch of gears falling out once I withdraw the shaft, and I live deep in the sticks so I can't afford to immobilize the vehicle by wrecking the transfer box.
RE: Defender transfer box oil leak
As far as I know, the only bits of the transfer box you can replace with it in situ are the front and rear output shafts, bearings and seals. Everything else is a box out job.
Have you asked this question anywhere else? If not I can relay your Q to another forum I know of, as a gearbox expert, I'm not
Cheers,
Cheers,
box, change, defender, defendertransfer, gearbox, intermediate, land, leak, lr, lr3, oil, rover, shaft, transfer, transferbox
