Defender Talk about the Land Rover Defender within.
Defender transfer box oil leak
Old Jul 8, 2007 | 05:47 AM
Fyko's Avatar
4wd High
Default Defender transfer box oil leak
I have an oil leak from the o-ring on the intermediate shaft of the transfer box situated mid-way between the input and output shafts.
Has anyone changed this o-ring with the transfer box in situ? How do you do it? I have the parts to do the job but am fearful of a bunch of gears falling out once I withdraw the shaft, and I live deep in the sticks so I can't afford to immobilize the vehicle by wrecking the transfer box.
Old Jul 10, 2007 | 07:05 PM
Adz's Avatar
Adz
Default RE: Defender transfer box oil leak
As far as I know, the only bits of the transfer box you can replace with it in situ are the front and rear output shafts, bearings and seals. Everything else is a box out job.
Have you asked this question anywhere else? If not I can relay your Q to another forum I know of, as a gearbox expert, I'm not
Cheers,
OffroadFrance
Aug 19, 2014 09:00 AM
taylor15
Feb 28, 2013 09:43 PM
conyza
Defender
Mar 22, 2012 12:20 PM
ant996
Defender
Sep 14, 2006 05:03 AM
Td5
Sep 1, 2006 05:01 PM
