Help me fix this leak - transfer box
Old Jan 29, 2013 | 07:07 PM
taylor15's Avatar
Default Help me fix this leak - transfer box
This is a leak that has been digging me for months. I finally pressure washed under the truck and pinpointed the main leak I'm after to the seal where the front prop shaft enters the transfer box. What is this seal called? I now have the rave and plan to tackle myself. Any advice appreciated. Below is a pic, sorry for the flashlight and cell photography.
Thanks guys.
Old Jan 29, 2013 | 07:08 PM
taylor15's Avatar
Oh, and I have put a bottle of white shepherd in with no luck. The worst is its dripping on the exhaust and smells pretty bad.
Old Jan 29, 2013 | 07:17 PM
br0keit's Avatar
this thing?
Output Shaft Oil Seal For Land Rovers - Part # FTC4939
Old Jan 29, 2013 | 09:18 PM
taylor15's Avatar
I think so. The pic didn't work last time, can you confirm by this terrible picture?
Old Jan 30, 2013 | 12:26 AM
jfall's Avatar
Mine drips. But I determined it would take many many miles to drain it.
I just check it every 6 months and top it off.
I put cardboard under the truck in the garage.
yeah, putting it off but..
Old Jan 30, 2013 | 06:58 AM
antichrist's Avatar
It's called the transfer case front output shaft seal and is easy to replace.
Old Jan 30, 2013 | 09:25 AM
You might want to inspect the flange shaft and make sure there are no groves warn into it, if there are, you should replace the front flange cause it will just start leaking again.
Old Jan 30, 2013 | 05:16 PM
antichrist's Avatar
If the surface of the flange the seal rides on is grooved there may be a Speedi-Sleeve that fits.
I forgot to mention that you'll need a new nylock nut for the oupput shaft.
I'll see if I can get one measured tomorrow to see if there's one that will fit.
Ok, it looks like Speedi-Sleeve PN 99177 may be correct. YMMV
Old Jan 30, 2013 | 06:03 PM
taylor15's Avatar
Thank you, that would be great. Are there any specialty tools I need for this?
Old Jan 30, 2013 | 08:17 PM
antichrist's Avatar
Torque wrench.
