Defender Talk about the Land Rover Defender within.
Engine Swap from Ford to Defender
Old Jun 20, 2018 | 08:52 AM
Asher111's Avatar
Lightbulb Engine Swap from Ford to Defender
Hi all Users,
I could really use all of your help here please!
My Land Rover defender engine just gave up. I have the latest model 2.2L efi Defender. I have heard that the Ford engines fit the Land Rover defender since they manufacture the engines for Land Rover as well. Ford has a 2.2 TDCi engine which is far cheaper than the land rover engine. Can you please advise that if the engines can be swapped? I have heard that the sump needs to replaced other than that the engines can be swapped without any additional work. Is this true or are there other parts to be changed as well. I understand that the anciliaries would be different such as injectors, pistons and so on. It is very urgent and I could use your help.
Similar to this my friend also has a older model with 2.4L engine. His engine has gone weak to and is willing to replace with a brand new engine. Like before the 2.4L engines is also manufactured by Ford. Can the ford 2.4L engine also be fitted on to my friends defender after changing the sumps? I am talking about stripped engines here meaning ancillaries are not included (i.e. pistons, rings. injectors etc) in the engine and will be purchased separately.
I hope that a technician can help with this with correct information as I cannot afford to buy the engines and it turns out they do not fit.
Regards,
Asher Malik
Old Jun 26, 2018 | 01:16 PM
DavC's Avatar
Hi Asher,
This forum is mostly North America centric, Candada/USA etc so we have much less experience with the later models like the 2.2, 2.4, Td5 etc. Your best bet would be to try Defender2.net forums which will have users with more firsthand experience with your specific motor. My understanding is yes you have essentially a ford duratorq motor that is specific to Defender and you could swap another unit in with some modification. My guess is that if your current motor is not too damaged you could simply swap over your old pieces to another 2.2
Best of luck
https://en.wikipedia.org/wiki/Ford_Duratorq_engine#2.2
Asher111
Engine & Internal
Jun 20, 2018 08:54 AM
Submariner
Defender
Apr 26, 2018 11:09 AM
DanEvans
Sep 28, 2015 09:08 PM
mandythelandy
Engine & Internal
Apr 9, 2008 01:15 PM
double R
May 16, 2007 06:05 PM
