Defender Talk about the Land Rover Defender within.
Flywheel timing off a tooth?
Old Feb 22, 2021 | 01:02 PM
L9FS's Avatar
Default Flywheel timing off a tooth?
Hi all,
I have a "new to me" '05 defender TD5 that is seriously lacking power in gears 3-5, hates hills. tops out at 90kph on a flat.
MAF is good, new stock turbo (oil leek in old one & shop cracked housing when trying to repair), EGR has been blanked, engine compression is 400psi, injectors are in proper position. New fuel, air & oil filters.
It looks like the timing hole for the flywheel might be off by 1 tooth when the crankshaft is aligned to its hole. not sure how that may have happened.. what would you expect as an effect if this is the case? it starts, idles and runs w/o knocking.
any ideas on what else to investigate would be greatly appreciated!
DiscoTime
Sep 17, 2019 08:35 PM
Joshua Hollahan
Feb 21, 2017 03:35 AM
robert.juric
Jan 9, 2017 06:52 AM
stratford4528
Jul 26, 2015 03:09 PM
LRScott
Jul 29, 2012 01:52 AM
