Hood (Bonnet) Release Cable Broken - Can't Open Hood
i'm in this situation because i just changed the LF headlight, must of disturbed the cable, and the inside, kick-panel level moves freely, no resistance, and the hood doesn't open .. i looked at it and the cable is there ... a little plastic circle is outside the LF release ... if i removed the bolts, TORX, for both sides(2 each), can i raise the hood enough to access the release tab ?
Bonnet cable broken
Thought pls?
Msny thanks
Chris
steveo2000
09-08-2015 08:00 AM
