Defender Talk about the Land Rover Defender within.
Hood (Bonnet) Release Cable Broken - Can't Open Hood
Old Oct 15, 2023 | 02:33 AM
qld2002's Avatar
Default Hood (Bonnet) Release Cable Broken - Can't Open Hood
2002 Land Rover Defender
The hood (bonnet) release cable broke inside the engine compartment.
How do I manually release the mechanism to open the hood?
Thank you.
Old Oct 15, 2023 | 03:45 PM
ues defender's Avatar
5th Gear
You should be able to remove the front grill and get to the latch from underneath the hood.
Old Dec 4, 2023 | 11:37 AM
wingding's Avatar
8th Gear
i'm in this situation because i just changed the LF headlight, must of disturbed the cable, and the inside, kick-panel level moves freely, no resistance, and the hood doesn't open .. i looked at it and the cable is there ... a little plastic circle is outside the LF release ... if i removed the bolts, TORX, for both sides(2 each), can i raise the hood enough to access the release tab ?
Old Oct 13, 2024 | 07:21 AM
ChrisH's Avatar
Default Bonnet cable broken
Guys I have removed the front grill and i can operate the latch but the cable hasn't released to allow the latch to work.
Thought pls?
Msny thanks
Chris
machinetech
May 8, 2016 08:20 AM
steveo2000
Sep 8, 2015 08:00 AM
Cookse7
Jan 17, 2015 10:38 PM
psyduck125
Jan 29, 2007 12:54 AM
kram2179
May 16, 2005 12:34 AM
