Defender Talk about the Land Rover Defender within.
noisy TD5
Old Apr 25, 2007 | 04:42 PM
bushtoy's Avatar
6th Gear
Default noisy TD5
Hey all!! need some advice...my Def TD5 is noisy, sounds like a petrol motor when it needs tappet adjusting. Are the tappets on the TD5 motor adjustable? Could it possibly be that i need a new oil pump? Planned a 5 day weekend and have got just one day to get it sorted so any advice will be great.
Pierre
Old Apr 26, 2007 | 08:38 AM
Adz's Avatar
Adz
Default RE: noisy TD5
Hi Pierre,
Yes the TD5 tappets are adjustable but I gather it's not the same as adjusting more traditional tappets. It might sound obvious - but check your oil level carefully with the car at it's normal running temperature too, could be that. Tappetty sounds can also be a worn rocker shaft.
What makes you think it might be the oil pump?
Cheers,
Old Apr 26, 2007 | 09:01 AM
bushtoy's Avatar
6th Gear
Default RE: noisy TD5 - Adz post
Thanx Adz.
The oil pump might be worn, so if the oil pressure is low and the tappets are hydraulic it seems plausible that the tappets would be noisy at idle.
Gonna open her up tonite and see what she is on about...will post my findings.
Pierre
pgaukroger
Feb 29, 2016 05:56 AM
unstable
Apr 26, 2008 07:58 AM
DiscoSam2
Aug 22, 2007 01:32 PM
trini defender
Defender
Dec 11, 2006 05:14 AM
jtysoe
Sep 19, 2006 04:35 PM
