A picture of what I found....
Hey here is a picture from just a quick glance underneath. Its a shot of the front of the transfer case. What do you think? I wanted to upload a few more pictures, but it wouldn't let me.
Thanks, David
Thanks, David
Judging by that pic, I'd say the bearing is shot - change it before you drive the truck again. I'm going to get a second opinion on the photo though - just in case it's something I've not thought of. I'll get back to you later
Cheers,
Cheers,
Me again. One thing that has me somewhat confused is the lack of any oil or grease coming out of the shaft. I would think if I had a bearing failure that there would be oil. Just my thoughts. What do you think? Hope to hear from you today. I will plan on taking the bus to Tirana tomorrow to the Land Rover Shop and hopefully purchase the new bearing. My truck may be down for awhileif they have to order from the UK.
Ok - spoken with a couple of other people, if it's not the bearing it might be the output shaft itself is bent. If that's the case you'll need a new bearing anyway as an impact hard enough to bend the shaft will mess with the bearing too.
When you take it to bits to replace the bearing , place the shaft on a clean flat surface and roll it along with the palm of your hand - you should be able to feel if it's bent as an irregularity in the way it rolls.
Cheers,
Cheers,
One last question? Do you know of anyplace on the internet that thye would have an exploded view of the transfer case for this 110? I don't have a service manual so any info would be greatly appriciated.
David
David
Thanks ADZ, I look forward to tearing into this. Any idea what a new shaft would run? I may have to order from the UK. I doubt they would have one in stock. I always hope to find a salvage yard for items like that, but I have not seen to many Defenders in the yards here. Thanks again.
David
David
bosshogt
Dec 23, 2011 10:24 AM
The Capstone
May 11, 2006 12:57 AM
