Defender Talk about the Land Rover Defender within.
Stage 1 clutch question
Old Sep 3, 2019 | 06:53 PM
CPTLOU's Avatar
Default Stage 1 clutch question
Hello folks,
Question to the oracle,
1983 Stage 1 with the 3.5 / 4spd manual......the powertrain is basically a Range Rover classic is that correct ?
That being the case, what clutch kit do I look for to replace it with ?
Most of the outfits don't even know what a Stage 1 is, and are set on either a Series III or a 110 clutch. Neither sounds right..
Advice would be most appreciated. Thank you in advance
Old Sep 3, 2019 | 06:58 PM
What trans do you have?
Old Sep 3, 2019 | 07:02 PM
CPTLOU's Avatar
4 Spd manual, which actual model, IDK, the stock one on an 83' Stage one ?
Old Sep 3, 2019 | 07:32 PM
well my memory says you probably have a LT95 trans/transfer case unit. If you look for the clutch kit for a early like 1983 110 it is the same
Old Sep 4, 2019 | 06:47 PM
CPTLOU's Avatar
Thank you very much for the info. Much appreciated !
Lou
markdeg
Nov 28, 2018 09:29 AM
pfjust
Defender
Nov 14, 2017 05:50 PM
roverclxx
Defender
Jun 27, 2017 04:29 PM
fredadog
Apr 3, 2006 06:10 PM
lugo35
Engine & Internal
Dec 13, 2004 05:51 PM
