Defender Talk about the Land Rover Defender within.
TD5 Starting Issues
Old Sep 28, 2022 | 07:43 PM
Sully94's Avatar
4th Gear
Default TD5 Starting Issues
Hello everyone,
I’m having starting issues with my 2003 TD5 Defender 110, and they don’t seem to stem from the usual causes (because I’ve had them in the past).
The car will eventually always start, but varies between firing on the first crank, and on the 5th attempt. It cranks nicely, but just seems to not want to fire. Some key points on it are:
  • Fuel filter recently replaced, with many many bleed cycles performed. There are no symptoms to indicate air in the fuel system. I’ve had plenty of issues with air in the system in the past, so I’m pretty familiar with the symptoms and am confident that this is not the issue.
  • No oil on the ECU.
  • Freshly replaced injector harness, and all injectors serviceable (recently had to replace two of them, others had no issues).
  • No battery issues.
A secondary issue (more bizarre than anything). Often after turning the key to position 2 and waiting for the engine light to go out, when I turn the key further to start absolutely nothing happens. There’s an electronic hum when the key is in the start position, but nothing else and no attempt to crank. The thing is…turn it off and then back on again and it will crank as normal.
Any thoughts or suggestions?
Sully
Old Oct 24, 2022 | 11:22 AM
captarmour's Avatar
I am new to this forum, did anyone answer this question? I have the same problem with my 2006 TD5 Defender
Old Oct 24, 2022 | 12:04 PM
Sully94's Avatar
4th Gear
No not yet, I’m away for work right now, but will most likely try new glow plugs next and see if that makes a difference.
Huskie
May 20, 2018 02:30 PM
discoHUSS
Jul 24, 2013 04:27 PM
shady milkman
Aug 31, 2012 04:58 PM
Rayyag
Freelander
Apr 25, 2009 09:31 AM
Spots and Dots
Dec 12, 2007 09:19 AM
