Detailing Discuss detailing your ride within.
Wheel with bad rust
Old Mar 22, 2008 | 10:52 PM
schultze5100's Avatar
Default Wheel with bad rust
I had a break pad issue that turned into a wheel issue, this has caused my rim to totaly rust, does anyone have an idea on how to get rust off these wheels without ruining the wheel its self?
Old Mar 23, 2008 | 05:09 PM
Default RE: Wheel with bad rust
Factory alloy wheels don't rust, they are not metal.
If you wheels are stained, might want to clean it with a liquid rust remover then re-wax the wheel because the rust remover will take some of the protective finish off.
Old Mar 23, 2008 | 08:24 PM
Ill take a picture tomorrow, if its not rust then it looks a lot like rusy and i have been trying to srcub with water and soap and it wont come up at all. I am afraid to use sprays because i dont want to ruin the rims all together...
Old Mar 24, 2008 | 10:08 AM
Trust me, I don't need a picture to know your alloy wheel is stained.
It will take a pretty harsh rust remover to remove the stain and as long as you clean and then wax your wheels afterwards, you'r be fine.
Old Mar 24, 2008 | 10:11 AM
Okay I will give that a try, thank you for your help Mike.... I also didn’t mean to come off as argumentative
Old Mar 24, 2008 | 01:09 PM
is the stuff i am looking for called liquid rust remover or just go to the local napa or somthing and ask what they have in that?
caymandrew
Mar 31, 2013 09:39 AM
forcefed44
Jan 15, 2013 04:17 PM
pinkytoe69
Apr 16, 2012 11:53 AM
Landifan
Jan 4, 2011 10:52 AM
Bene
ROAMING WITH FRIENDS
May 11, 2005 04:33 AM
