[HELP] Center Differential Lock
Old Apr 29, 2012 | 05:53 AM
  #81
WaltNYC's Avatar
Answering your question about locking the CDL......
You can lock/unlock the CDL at any speed in any gear. however, you must be in neutral to shift between high and low range gears.
So, looking at the CDL shifter.... Right to left anytime, fore and aft only in neutral.
It's worth noting that your CDL won't engage if your vehicle is already in a position where one wheel is already spinning. Engage the CDL before wheel slippage occurs.
Old Apr 29, 2012 | 08:34 AM
  #82
Ed Z's Avatar
Possibly the plastic bushings in the linkage pins have worn out or are damaged... This may cause excess play in the linkage movement...
Old Jan 25, 2013 | 06:22 PM
  #83
NabisOne's Avatar
Thanks to everyone who commented on this post. My CDL got stuck in diff lock and i ended up pulling the entire shifter out, took it apart and cleaned it all. it was full of hardened reddish brown grease and was extremely dirty. Once i cleaned and regreased it, it works like it should. Thanks again.
Rob.
TripleThreat
Jan 2, 2012 08:38 PM
dino109
Jan 1, 2012 12:06 PM
Noah360
Sep 6, 2009 10:05 PM
mrossipir
Jan 1, 2009 10:54 AM
audiurq
Jul 1, 2007 11:52 PM
