12v constant power in interior fuse panel?
Old Feb 20, 2016 | 11:41 AM
Toran's Avatar
Default 12v constant power in interior fuse panel?
Hello Good People,
Is there a 12v constant power wire I can tap into from within the interior fuse panel? I was hoping to find something without having to connect a jumper wire directly from the battery.
T.I.A.
Old Feb 20, 2016 | 04:22 PM
fishEH's Avatar
Not that I'm aware of. Snaking a couple wires from the battery through the firewall grommet is super easy though.
Old Feb 20, 2016 | 04:25 PM
Joemamma1954's Avatar
Originally Posted by Toran
Hello Good People,
T.I.A.
Yes, there are a couple of ways. 1. Get a piggy-back fuse and check each fuse to see which one is constant.
2. There are two unused slots on the lower right hand side of the box, and there is a vendor that sells the plugs. One plug is a single wire and 20 amps, the other has 4 slots, some are constant, some are switched.
I think his name is Paul at lrconnectors. I went this route to power additional charging port for phone.
I will post some pics for you when I get off work this evening.
Old Feb 20, 2016 | 04:56 PM
Toran's Avatar
Thank you Good People!
Much appreciated
Old Feb 20, 2016 | 06:28 PM
lrconnector from UK
plug for s12
lrconnector from UK
plug for s13
lrconnectors from UK
S13 is 20 amp unstitched
Old Feb 20, 2016 | 06:30 PM
lrconnector from UKHere are pics of Paul's connectors. He also gives you the breakdown of what wires are what.
This is for S12:
The circuits are as follows -
Terminal-5 - Live - ignition switched (position 1 on ignition switch), via fuse F27 (10 Amps)
Terminal-4 - Live - permanent, via fuse F20 (15 Amps)
Terminal-3 - Live - switched, from auxiliary circuits relay, via fuse F15 (20 Amps)
Terminal-2 - Live - from main lighting switch (sidelights position), via fuse F33 (10 Amps)
Terminal-1 - Earth - via C0583 to C0017-1 (Earth Header) on 3.0mm² cable
Old Feb 20, 2016 | 06:40 PM
Toran's Avatar
Very nice!
Thank you!
Old Feb 20, 2016 | 07:30 PM
Toran's Avatar
Would you by chance have the site location to this lrconnectors?
Still lookng...
Thanks
Old Feb 20, 2016 | 07:35 PM
here is his email:
lr_connectors@btinternet.com
I contacted him and ordered from him.
Old Feb 20, 2016 | 07:36 PM
Toran's Avatar
Auhhh I see.
Thank you for the help.
