12v constant power in interior fuse panel?
Old Feb 20, 2016 | 07:51 PM
fishEH's Avatar
You remember what the pricing was, approximately?
Old Feb 20, 2016 | 09:57 PM
Joemamma1954's Avatar
I remember it being about 20.00 shipped from UK. Paul is very knowledgeable and friendly.
I ordered both connectors and they come with extra pins, in case you F-up.
Makes for a very clean OEM looking install. And you have 5 total switched and un-switched power sources and a ground on the multi-pin connector.
Old Feb 21, 2016 | 09:58 AM
PaulMc's Avatar
My post and pictures that have been quoted above, are for a Discovery-2, which has a different interior fuse box to the Discovery-1
I’m not too familiar with the Discovery-1 fuse box – so, I had a look through Land Rover’s installation instructions for Discovery-1 accessories (DVD, Navigation System, Mobile ‘phone).
Unfortunately, these appear to be the same accessories and instructions for the Discovery-2, and they show a Discovery-2 fuse box in their diagrams.
Looking at pictures of a Discovery-1 fuse box, there appears to be some unused connector ports – none of which, are the same as the S12 and S13 sockets in a Discovery-2’s fuse box.
I would suggest that you use a meter or a test lamp on the fuse box in your Discovery-1, to determine if any of these unused connector terminals are permanently live.
Otherwise, the previous suggestion of using a ‘piggy-back’ fuse, is probably the easiest solution.
Old Feb 21, 2016 | 10:20 AM
number9's Avatar
Is there a 12v constant power wire I can tap into from within the interior fuse panel? I was hoping to find something without having to connect a jumper wire directly from the battery.
Can you read wiring diagrams/schematics? If you can they are helpful and available to download for free.
Previous practical experience replies excellent as usual.
Recall fuse 12 appears to be hot/un-switched.
File Type: pdf
Old Feb 21, 2016 | 11:30 AM
PaulMC
Thank You for your knowledge and help on this matter. My Bad, I should have seen that it was a D1. Like you said, the piggy-back fuse connection, may be his best option, other than going from engine bay fuse box or battery.
Joe
Toran's Avatar
Thanks Paul for the quick email and thread response!
Thanks number9 for the wiring diagrams. I really dont understand it so I'll look at fuse 12
Old Feb 21, 2016 | 11:32 AM
Toran, sorry for the misinformation, I should have been more alert on the model.
Joe
Old Feb 21, 2016 | 11:33 AM
Toran's Avatar
Not a problem Joe, thanks for chiming in to help!
Old Feb 21, 2016 | 11:35 AM
number9's Avatar
Good idea to learn some basic electrical if you plan on keeping a LR around.
Old Feb 21, 2016 | 11:36 AM
Toran's Avatar
Agreed!
