1994 disco front sway bar?
Old Aug 28, 2019 | 02:35 PM
Roverup's Avatar
Default 1994 disco front sway bar?
Can someone tell me if in 1994 the disco came with or without a front sway bar? Mines doesnt have one. Not sure if it was removed by previous owner or not.
Old Aug 29, 2019 | 07:22 AM
OverRover's Avatar
DI's did come with a front Anti Sway Bar. Most likely your was removed.
The first pic shows the ASB mounted to the 2 brackets that are welded to the frame.
The 2nd pic shows the 2 LINK END mount points on the axle.
And the last pic is of the ASB removed, but even removed you will always see the 2 brackets ON THE FRAME.
Old Aug 29, 2019 | 08:29 AM
Roverup's Avatar
Thanks
Old Sep 9, 2019 | 03:38 AM
BierNut's Avatar
Pick-n-Pull keep checking you should be able to find a replacement bar but also get the straps and hardware plus the end links and hardware.
I would at least add Poly bushings front and rear.
Presently in the process of pulling parts off a 95 D1 at a Pick-n-Pull, a street roll over with both anti-roll bars missing, go figure? Bad enough handling with factory ant-roll bars. If driving on the street.use the bars but add removable links if you must have full suspension travel off road but not on the street for yours and others safety.......~~=o&o>........
Alex_M
Aug 26, 2021 09:03 PM
coors
Apr 1, 2018 08:56 PM
JimmyG
May 28, 2014 06:38 PM
Fallstaff
Mar 18, 2013 09:05 AM
Soccer Dad
Jun 10, 2010 04:52 PM
