1995 Disco - Cranks but Won't Start
Old Aug 28, 2020 | 11:49 AM
LipLounge's Avatar
Question 1995 Disco - Cranks but Won't Start
Purchased this disco a couple months ago. Drove it from Salt Lake City to so cal and it didn't miss a beat. I was parked and idling when the engine cut out. It didn't run rough or feel like it was misfiring. Just sort of died. I've got 34 psi at the fuel rail. Check. I've got a new ignition coil that sparks blue. Check. No spark at spark plugs when tested with spark test tool. Spark plugs and spark plug wires are new. I ordered an original used distributor,( pain in the *** to find by the way). Are there any other auxiliary ignition parts that I should check before replacing distributor? Or next steps if replaced distributor doesn't get it running again?
Thanks in advance.
Old Aug 28, 2020 | 12:53 PM
Best4x4's Avatar
Check the cap (make sure the little center button isn't stuck). Then check the rotor = they can crack & fail = no spark at the plugs. Push down on the shaft when removing the rotor!!
Old Aug 30, 2020 | 11:54 AM
LipLounge's Avatar
That did it! I had checked before but didn't notice cracked rotor. Pulled the cap off and the rotor fell out in pieces. Pressed on new rotor and she fired up first try. Thanks! My summer can finally start!
Old Aug 30, 2020 | 12:00 PM
Best4x4's Avatar
No problem at all
Matt Couleur
Sep 22, 2019 03:51 PM
Dinknose
Feb 16, 2018 11:40 PM
Captian Adrianus
Sep 8, 2012 08:45 PM
glmtd
Jan 8, 2010 11:51 PM
NWDisco
Dec 13, 2006 03:11 AM
