1995 Discovery-- wrong MAF sensor??
Old May 21, 2017 | 01:53 PM
stevee's Avatar
Default 1995 Discovery-- wrong MAF sensor??
Checked the number on the Fuel Inj Corp installed by PO or "mechanic"-- 165575-- reference from supplier says its for 2.0 VW, and the correct one for my truck should be their #460618. I assumed its new and proper and good-- but ?? Interchangeable?
Old May 21, 2017 | 05:09 PM
DiscoCam's Avatar
Not sure if the 3.9 MAF is different than the 4.0 or not, but yours looks way different from the one on my '99 D1. Mine is black plastic.
Old May 21, 2017 | 08:58 PM
stevee's Avatar
From what I find in other postings + online, the '94- '95 Discovery shares MAF w/ '88 to '95 RRC and similar age Jaguars. Will call the Fuel Injection Corp in the a.m. and see whether the one on my Landy is appropriate or not.
Old May 21, 2017 | 10:36 PM
XCELLER8's Avatar
yes....the '94-'95 s are different than the 96 and up........yours "looks" as it should ....but I cant speak as to the part # they are using.....you have what is refered to as a "14CUX" fuel injection system.....96 and up to early 99 are "GEMS"
Old May 22, 2017 | 02:06 AM
DiscoCam's Avatar
PartsGeek has this listing for the '87-'95 RRC.
1987-1995 Land Rover Range Rover Air Mass Meter - Air Intake - Fuel Injection Corp. 87-95 Range Rover Air Mass Meter - 285-01139104 - PartsGeek
Looks like the one on your truck.
Old May 22, 2017 | 07:06 AM
OverRover's Avatar
The MAF in your pic looks correct (at least from the outside) for a '95 DI w/ 3.9 liter.
The Land Rover part number is ERR5198. It looks like AB sells this as a Reman #ERR5198K.
The part numbers from Fuel Injection Corp are their internal #s. And you "assumed its new...", well it was at one time, but FI Corp REMANUFACTURES these parts. I know nothing of this company, but just based on how many other "applications" they have listed wrong (for LR and other makes) on their website, that looks like a 5th grader made it......Good Luck. >>> Fuel Injection Corporation
Old May 22, 2017 | 03:35 PM
stevee's Avatar
Did get hold of FI Corp this a.m. Very polite, said yes this is the correct one etc. (After finding a wrong distrib, junkyard inertia switch that was inop, and not knowing the MAF story, I trust very little of the work done previously on my truck.) Bought a fuel pressure kit today, and will test pressure before during after and later. Also poured in the Seafoam cleaner.
Old May 22, 2017 | 03:53 PM
Best4x4's Avatar
Slap on a Chevy fuel pump. I'm using a Delphi unit I got from Auto Zone in my 98 D1. It's been in there nearly 2.5 years now. When I tore my original apart the fuel sock that mounts to the pump was completely in about 10,000,000 pieces. Whole install took me maybe 1hr from start to finish. I've seen pictures where people cut out the floor or remove interior trim, but I just removed the rear door/carpet finisher, and was able to pull the carpet up and out enough to get to the pump.
Old May 22, 2017 | 05:03 PM
stevee's Avatar
Bought a fuel pressure tester at Harbor Freight for $19.99-- works w/ schrader valve type vehicles, not Bosch tho. Hooked it up, pressure jumped to 33-34# immediately w/ key to position 2. Backed off to 32#, did key on again, up to 34# and held. BUT: after 1/2 hr, its down to 22#. Likely leaking past injectors into cylinders, causing the hard start? ps-- new oil has a gasoline smell to it. After 1 hr, holding at 20#.
KlamathMatt
Apr 17, 2020 05:27 AM
nickm347
Nov 8, 2016 05:01 PM
Jason428sc
Sep 11, 2013 06:31 AM
bbeeff
Dec 11, 2007 12:28 PM
Different Drummer
Oct 1, 2006 07:03 PM
