1995 Front fender antenna
Old Nov 29, 2019 | 05:15 PM
Brig_2016's Avatar
Default 1995 Front fender antenna
Hello all, I recently purchased a new to me 95 5 speed D1 in Avalon blue. 65xxx in the clock. Truck is very well sorted but have been slowly working through it and can’t seem to find much info on the front fender antenna. There is one installed, but it doesn’t raise up and I can’t pull it up. IS it supposed to automatically raise when the truck turns on or does it just stay in the fender at all times? Thanks for any info on this.
Old Nov 29, 2019 | 05:55 PM
Gorgeous Disco welcome to the forum
Old Nov 29, 2019 | 06:17 PM
OverRover's Avatar
Providing that is the original LR antenna ( AMR 3461 ) then it's manually retractable.
Hit it with some WD-40 and see if it frees itself. If not just replace it, they are cheap enough.
Some info for you...
> https://www.roverparts.com/Parts/AMR3461
> https://www.roverparts.com/Instructi...na_AMR3461.cfm
Old Nov 29, 2019 | 07:08 PM
Brig_2016's Avatar
Ok great, I’ll work the WD-40 and go from there. Thanks for the info!
toofaroffroad
Dec 26, 2016 02:12 PM
willz33
Mar 9, 2011 06:00 PM
discoxd
Aug 24, 2009 01:11 PM
ainiguez
May 18, 2009 09:39 PM
tdthermal
Nov 23, 2007 07:20 PM
