1995 Range Rover and discovery sway bar ball joint
https://www.walmart.com/ip/Land-Rove...E76L/133374707
do y’all trust this?
these trucks sit on same chassis right?
Problem is usually with a 2inch lift the rear sway bar link will rotate and cause the RRC/D1 to sit with one side up and one side down. My 98 LSE D1 would always do it at this one gas station I used to visit often. It got to be a PITA. My specifically setup D1 for off road use = no F/R sway bars at all and I've got used to how it handles. I don't drive it all fast n furious but without em it certainly helps get the most out of my setup.
JohnZo (06-03-2022)
