1996 Transfer case
1996 Transfer case
I SHOULD, after 7 mo, get my 1996 D1 SE that I bought for PARTS but it looks like I will probably restore it and put Mutley into service at the Hunting camp.
This unit has 231,125 miles and the engine checked out PERFECT with less than 5# across the cylinders.
1. How much work is putting in a transfer case in.
2. What should I expect to pay for a low miles used one
Thank you.
Thank you.
on
There is no such thing as a low mileage 15 year old t/case, especially a good 96 since they had so much trouble with one of their shaft failing. Rover did do a quick modification to that shaft by drilling a hole thru it so oil would flow, but there are a lot of those old ones out there. Might consider buying a 97 or 98 t/case and have it opened up and inspected, resealed before installing. Also use an 85W/140 gear oil.
What about the rest of the truck, have you done a major service to get it current?
What year cases fit this 96? I have access to a bunch of them I THINK if the guy is not full of BS.
on
George, here's a similar write-up with a source for both used and rebuilt t cases.
https://landroverforums.com/forum/sh...ad.php?t=35836
Good luck.
Good luck.
dennyb
04-16-2011 07:43 PM
RoverLover
03-02-2006 05:01 PM
