1996 Transfer case
Old Nov 15, 2010 | 06:58 PM
georgep's Avatar
Question 1996 Transfer case
I SHOULD, after 7 mo, get my 1996 D1 SE that I bought for PARTS but it looks like I will probably restore it and put Mutley into service at the Hunting camp.
This unit has 231,125 miles and the engine checked out PERFECT with less than 5# across the cylinders.
1. How much work is putting in a transfer case in.
2. What should I expect to pay for a low miles used one
Thank you.
Old Nov 16, 2010 | 07:34 AM
Jull's Avatar
I paid 200$ for mine unknown mileage. It took me 3 days of sporadic work, and I wasn't equipped with either a lift or a pit.
Old Nov 16, 2010 | 09:01 AM
There is no such thing as a low mileage 15 year old t/case, especially a good 96 since they had so much trouble with one of their shaft failing. Rover did do a quick modification to that shaft by drilling a hole thru it so oil would flow, but there are a lot of those old ones out there. Might consider buying a 97 or 98 t/case and have it opened up and inspected, resealed before installing. Also use an 85W/140 gear oil.
What about the rest of the truck, have you done a major service to get it current?
Old Nov 17, 2010 | 11:00 AM
georgep's Avatar
It is still sitting in the field where I bought it 7 mos ago. The title has to be gotten from the state as it is a mechanics lean that has been collecting storage for 3 years at $25.00 per day.
What year cases fit this 96? I have access to a bunch of them I THINK if the guy is not full of BS.
Old Nov 18, 2010 | 09:58 PM
Danny Lee 97 Disco's Avatar
George, here's a similar write-up with a source for both used and rebuilt t cases.
https://landroverforums.com/forum/sh...ad.php?t=35836
Good luck.
Old Nov 19, 2010 | 09:17 AM
Find a low milage one and inspect it first, 99 D1 or older but not older then your 96.
dennyb
Apr 16, 2011 07:43 PM
dennyb
Apr 15, 2011 03:14 PM
RoverLover
Mar 2, 2006 05:01 PM
Loose_Screws
Jul 22, 2005 12:13 AM
Smokeyone
Jun 4, 2005 03:11 AM
