1997 disco fuel pump options
well... looks like fuel pump... read this suggestion on another forum... any thoughts?
"You can also do the "cheap bastard" fix by installing a late 80s GM fuel pump. from like a 1989 seville."
money lil tight to be a purist... :-)
If you go the GM fuel pump replacement route (Airtex 3270 ?) be careful about using good hose and clamps in the fuel pump assembly that goes in the tank. I know from personal experience that the ends can split or blow off. If this happens, the pump will run, but the fuel won't get out of the tank. Just a friendly hint.
From the RAVE electrical manual, under instruments (you know you want your own copy):
will illuminate to warn the driver .
Note to others, that fuel light comes on at 1.5 gallons, and you are 35 miles to next gas station......
When the fuel tank level is low, the resistance of the
fuel gauge sender is approximately 245 ohms. As the
fuel level increases, the resistance of the sender
decreases, causing the gauge to register the change.
When the fuel tank is full, the resistance of the sender
is approximately 19 ohms. When the fuel gauge
sender’s resistance falls below approximately 25
ohms (6 liters/1.5 US gallons), the fuel warning light
Fuel line and fuel line clamps. When you replace the plastic straw with the fuel line don't make it too long. The pump assembly will compress a bit on installation and you don't want the new hose kinking.
