1997 disco fuel pump options
Old 04-12-2012, 10:49 AM
RobertBrowning's Avatar
Default 1997 disco fuel pump options
well... looks like fuel pump... read this suggestion on another forum... any thoughts?
"You can also do the "cheap bastard" fix by installing a late 80s GM fuel pump. from like a 1989 seville."
money lil tight to be a purist... :-)
Old 04-12-2012, 12:34 PM
Chris-bob's Avatar
Have you used the search function? This has been covered in many threads already.
Old 04-12-2012, 12:55 PM
Old 04-12-2012, 01:10 PM
DiscoJag's Avatar
If you go the GM fuel pump replacement route (Airtex 3270 ?) be careful about using good hose and clamps in the fuel pump assembly that goes in the tank. I know from personal experience that the ends can split or blow off. If this happens, the pump will run, but the fuel won't get out of the tank. Just a friendly hint.
Old 04-12-2012, 03:35 PM
Default Omfg
How did you get that plastic ring off that holds the fuel pump? mashed all my knuckles but the mechanic gods don't see it fit 2 cut me some slack... thx...
Old 04-12-2012, 04:13 PM
pinkytoe69's Avatar
Put a big flathead screwdriver on one of the ridges and tap the butt end with a hammer till it loosens up.
Old 04-12-2012, 05:46 PM
that did the trick thx... sucker was really stuck on there...
Old 04-12-2012, 05:49 PM
how do you test the sending unit? was going to use a Airtex E3270 to replace actual pump... have i stated how awesome ya'll are today?
Old 04-12-2012, 08:00 PM
From the RAVE electrical manual, under instruments (you know you want your own copy):
When the fuel tank level is low, the resistance of the
fuel gauge sender is approximately 245 ohms. As the
fuel level increases, the resistance of the sender
decreases, causing the gauge to register the change.
When the fuel tank is full, the resistance of the sender
is approximately 19 ohms. When the fuel gauge
sender’s resistance falls below approximately 25
ohms (6 liters/1.5 US gallons), the fuel warning light
will illuminate to warn the driver .
Note to others, that fuel light comes on at 1.5 gallons, and you are 35 miles to next gas station......
Old 04-12-2012, 08:48 PM
fishEH's Avatar
Fuel line and fuel line clamps. When you replace the plastic straw with the fuel line don't make it too long. The pump assembly will compress a bit on installation and you don't want the new hose kinking.
Quick Reply: 1997 disco fuel pump options
