1997 Disco too slow
Old Oct 24, 2023 | 05:23 PM
  #21
czerta's Avatar
Did 16hr of highway at 80mph in the disco 1 4.0 the other weekend. I didnt find power to be a major issue even driving through nebraska and iowa with hills+wind. Door seal noise was more of an issue until I jammed 1/4 tubing into the D2 seals I have in the car. Rpms sat at ~2800-2900 constant cruising. Ive also done 32hr of 80mph in a different disco 1 4.0 with 3 pass and enough gear to choke a horse, but that one had stage 6 weight savings in the form of rust holes through all the floorpans
Now admittedly my setup is more or less stock and I was only hauling 1 pass. But you should not have as much issue as you are on rolling terrain or even holding 80mph. I would ensure adaptives are correctly set and you dont have any leaks in intake/plen. Then I would swap to the bigger orange injectors, that had the largest single effect on sluggishness of my 4.0s
Old Oct 24, 2023 | 07:00 PM
  #22
Harvlr's Avatar
Land Rover used too small of injectors?
Old Oct 25, 2023 | 08:35 AM
  #23
whiskeynipple0088's Avatar
are these the injectors you speak of - Bosch 0280155746 ?
Old Nov 1, 2023 | 02:27 PM
  #24
czerta's Avatar
They were probably fine when brand new and using high quality gas. But by now your truck has been sucking junk gas for ~30yr and those injectors are likely tired and not spraying as well as they did at one point. The big orange injectors have a vastly superior spray pattern and 30 years less use on them of course. Injectors arent that bad of a job, maybe a 2/5 if oil is a 1/5. Perhaps a 3/5 if you have fat hands or a giant lift. Just make sure you get some anerobic gasket maker to re-seal your intake on reassembly.
The big orange injectors and the adaptive reset improved the performance of the car for me a good bit.
Yep
Old Nov 1, 2023 | 04:21 PM
  #25
WaltNYC's Avatar
Did 16hr of highway at 80mph in the disco 1 4.0 the other weekend....
My truck would be at 3,100-3,200 or so at 80 mph.
edit: 80 on the speedo would be 2800-2900
80 on the GPS (waze) is 3100-3200
Old Feb 15, 2024 | 04:41 PM
  #26
Hatchetjack's Avatar
The manual trans definitely makes them “feel” faster. :/
but compared to modern SUVs they just aren’t. Sometimes I wish there was a sixth gear, but 80mph on springs, a solid axle, and 100” wheelbase is kinda dicey as it is. It’d be spookier with a lift to me.
guevara42
Oct 27, 2017 12:13 AM
deseraligears
Jan 26, 2010 10:06 AM
Chris in Maui
Mar 25, 2009 12:27 AM
suntattoo80
May 29, 2007 11:11 PM
StephenK1706
Jan 17, 2005 05:45 PM
