1998 4.0 o2 sensor part #
Old Feb 2, 2011 | 02:51 PM
swank1975's Avatar
Default 1998 4.0 o2 sensor part #
I have read that my Disco has 4 of the same 4 wire heated O2 sensors. I currently have the P1193 downstream open heater circuit CEL and I'm wanting to resolve it. I'm going to do a little troubleshooting to check the resistance of each o2 for 6ohms of resistance across the sensors heating element. I keep seeing mention of "buy it off amazon" when I search but I have not yet seen what part number to get. Mine is the advanced EAL stuff for emissions also. I think that makes my sensors more expensive. I'd like to do all 4 at once but the cheapest sensor I've seen so far is $130 each.
Thanks. I really did try multiple times to find this via search. I downloaded RAVE for the first time today and I'm totally lost in it.
Old Feb 2, 2011 | 04:09 PM
antichrist's Avatar
RAVE won't tell you the part numbers.
You can always go to the NTK website.
Here's one of my posts about them.
https://landroverforums.com/forum/sh...7&postcount=10
Old Feb 2, 2011 | 04:39 PM
happyD1owner's Avatar
Default oxygen sensors
I bought mine from J.C. Whitney for around $70.00 each. They are NTK , and are exactly like the ones that were on it.
Old Feb 2, 2011 | 04:54 PM
Only buy 2, only the front ones control engine fueling and because all four are the same you can take one of your good front O2's and stick it in place of your bad down stream one.
Old Feb 2, 2011 | 05:08 PM
swank1975's Avatar
Thanks just ordered mine..
Old Feb 2, 2011 | 09:13 PM
swank1975's Avatar
Oops. Too late. I ordered all 4 sensors. Well I should be good for a long time in the O2 category. I'll check to make sure everything else is optimized also so I don't have a engine problem that causes early failure. It would be cool to throw in a extra bung so I could hook my LM1 wideband up to it and watch how it does.
KlamathMatt
Apr 17, 2020 05:27 AM
clark56
Jul 4, 2013 01:46 PM
clark56
Jun 29, 2013 10:02 AM
R White
Jan 30, 2013 09:43 AM
zer0Point
Nov 17, 2012 04:52 PM
