1998 Disco no spark issues
Old Sep 20, 2014 | 05:24 PM
  #21
snydesh's Avatar
I took the coils off again. They ohmed out good. 1.1 on the primary, and 13.5 on the secondary on each.
Old Sep 21, 2014 | 12:38 PM
  #22
snydesh's Avatar
The Tack doesn't work when I turn the motor over either.
Old Sep 21, 2014 | 05:30 PM
  #23
snydesh's Avatar
I pulled the inspection cover on the crank case and all the teeth look good, and the crank sensor sits inbetween them as it should I guess. I am about ready to sell it.
Old Sep 21, 2014 | 08:30 PM
  #24
ihscouts's Avatar
Find the "Main" relay. Take the cover off and check the contacts. If it has failed call the bone yard you snagged the ECM and 10AS ask them if they have a "Main" relay. Must be a 98 or later since you have AEL.
Main relay
The main relay supplies the power feed to the ECM
with a tap off to feed the fuel injectors (8 amps) and
air flow sensor (4 amps). This relay is controlled by
the engine management ECM. This enables the ECM
to remain powered up after ignition is switched off.
During this ’ECM power down routine’ the ECM
records all temperature readings and powers the
stepper motor to the fully open position. Failure of this
relay will result in the engine management ECM not
being switched on resulting in engine not starting due
to absence of fuel and ignition.
Old Sep 21, 2014 | 11:11 PM
  #25
snydesh's Avatar
I believe I found it. Black box next to the ECM with two plugs going in it. I took the cover off and it all looks good. I also have power to the ECM. I also have fuel and sometimes spark. I was working on it today and it lit me up once.
Old Sep 22, 2014 | 03:27 PM
  #26
snydesh's Avatar
I found no issue with it. I even forced the contacts and it made no difference when I tried to crank the motor.
Old Sep 23, 2014 | 09:34 PM
  #27
snydesh's Avatar
Ihscouts is that the main relay?
Old Sep 23, 2014 | 09:42 PM
  #28
ihscouts's Avatar
Yes, just in front of the ECU. It's a split relay box, one side is the fuel pump and the other side is the "main" relay.
I'm running out of ideas. The only other device that would effect spark is the crank sensor.
Have you checked every fuse on this truck? All the engine bay fuses, all the fuses under the steering wheel? I mean other than these there would have to be a wire loom problem at a splice or like the knock sensor - have wires fused together.
Old Sep 24, 2014 | 07:57 AM
  #29
snydesh's Avatar
I have checked every fuse at least 10times, I even cleaned the connections. The Knock sensor did have wires fused together. I spliced it at the plug and ran new wires. I will ohm it out to the ECM today and make sure they are not fused somewhere else. I will also ohm out the crank sensor wires. Don't give up on me ihscouts you are the only one in here that is helping. A guy on another forum suggested running the motor and measure the readings off the Crank sensor. Do you have any input on how to do this? i was going to try that as well.
Old Sep 24, 2014 | 11:31 AM
  #30
Gimebakmybulits's Avatar
Is there any chance that the ECM & alarm module that they sent are not a matched pair? I'm still too new to these but I have a running 98 LE and if you have certain electrical readings you want let me know and one evening after work we can do a call and work through a few things if you want.
John
