1998 Disco no spark issues
Old Sep 29, 2014 | 04:41 AM
  #41
ihscouts's Avatar
A shot in the dark is worth twenty in the light so far. That sounds like a feasible reason so check it out Shane.
Old Oct 2, 2014 | 04:23 PM
  #42
snydesh's Avatar
I tried it no change.
Old Oct 7, 2014 | 01:37 PM
  #43
snydesh's Avatar
I'm going to change the Cam sensor. Ordered it today.
Old Oct 9, 2014 | 09:08 AM
  #44
snydesh's Avatar
Ok I installed the Cam Sensor and it fired up but it idles great with no miss. I took it for a ride and quickly realized it cuts out going up a hill or trying to accelerate. When I got back home I realized I had left the fuel pressure sensor plug unplugged. I plugged it back in while it was idling and it shut of the motor. I cranked it back but it would not idle and ran bad. I unplugged it and slowly increased the throttle and when it gets over 2.5K rpm it will fall back to 2K rpm and then go back up, and fall again. I am going to check fuel pressure and see what is going on. Any input?
Old Oct 10, 2014 | 02:09 PM
  #45
snydesh's Avatar
For anyone else. I finally found a Rave I could download.
https://www.cubbyusercontent.com/pl/LR3%2bworkshop%2bmanual/_fea250a5711943a885e54ed37cc7a7ed#LR3%20workshop%2 0manual
Old Oct 10, 2014 | 10:05 PM
  #46
XCELLER8's Avatar
as a couple of us have found.....that sensor on the fuel tank is tied into the same circuit as the TPS, IACV.....there is a chance that when the sensor went ...it took out the tps or something else....maybe get the truck hooked up to a live scanner to find out whats working and not ??
Old Oct 14, 2014 | 09:24 AM
  #47
snydesh's Avatar
What type of scanner do I need. I may purchase it depending if it will match up with my other car/trucks.
Old Oct 14, 2014 | 12:11 PM
  #48
ihscouts's Avatar
Most here buy an UltraGauge ( UltraGauge OBDII Scan tool & Information Center ) because it will work with any vehicle and it's relatively cheap @$60.00.
Old Nov 10, 2014 | 01:54 PM
  #49
griggan's Avatar
Smile No Spark
Hi don't know if you got your 98 Disco 1 running yet. I am new to the forum stuff, with this being my first input. Late this fall I purchased a 98 Disco 1 that was not running. A friend of mine is a Land rover enthusiast and mechanic so had him helping to trouble shoot. My disco had no spark and no fuel at the rail. We went through a bunch of stuff ECU, Multi Function Unit, replaced the Crank Position sensor but to no avail. the ECU and Multi Function Unit were working fine. We finally got word from another Edmonton area enthusiast who had similar issues with his 98. Turns out it was a ground problem. Take the vertical kick panel off the right passenger foot well (two plastic screws) and in behind are a few relays. Smack in the middle is a ground point with a number of ground wires to it. (Mine looked really clean but took it apart as I was already there) sanded the contacts lightly with sand paper and put it back together and with first turn of the key it fired up.
As I mentioned when I looked at the ground it looked fine, so there must have been a fine film enough to prevent connection.
Old Nov 10, 2014 | 01:59 PM
  #50
griggan's Avatar
I found a junk yard that has the vehicle with the ECM andthe Alarm module, but the guy needs to know where the alarm module is locatedand what it looks like. I am not realsure myself. Can anyone point me to itso I can relay that information to the junkyard and get this Rover going. J
