1998 Discovery 1 LE - White on Beige
Old Aug 31, 2017 | 12:01 AM
  #31
egebhardt's Avatar
Thanks. 2 steps forward, 1 step back.
I got 4 new lug nuts in the mail today. Some were boogered up so I wanted to replace those. Also, I was able to get the door key made from a broken one. Years ago, the key was broken off in the ignition and a new ignition needed to be found. The new ignition had a different key. The locksmith was able to make a new key by mounting both pieces in their vice, then cutting a match. I got lucky and it worked. I don't want to leave this thing unlocked all the time.
All good above but then i found the transfer case to be leaking at 2 bolt holes after I just drained and filled it. I tried like hell to get the inspection cover off in order to re-seal it, however, it was stuck on there really good. The only way to get this FRC 5415 transfer case off will be to break it. Then I can re-seal it around the bolt holes. Does anyone know where I can find an FRC 5415? It was on all Disco1 and 2s with that LT230 transfer case.
Thanks in advance.
Old Aug 31, 2017 | 05:29 AM
  #32
Matt927's Avatar
https://www.rimmerbros.co.uk/Item--i-FRC5415
Use Permetex The Right Stuff to reseal...
Old Aug 31, 2017 | 06:40 AM
  #33
egebhardt's Avatar
Thanks. I should have clarified. I'm looking for a case cover in the US. There are tons 5,000 miles away in the UK.
Permatex Right Stuff has a 200psi shear strength? I don't want to glue it on nearly as tight as it is. Regular RTV can do the trick. If the thing wasn't glued on so dam hard right now, I would have gotten it off and re-sealed it without a problem.
Old Aug 31, 2017 | 06:54 AM
  #34
Matt927's Avatar
Regular RTV usually ends up leaking again.
Try Paul Grant for a used cover.
Old Aug 31, 2017 | 10:07 AM
  #35
egebhardt's Avatar
Ok. Thanks. what is Paul Grant's username? A search reveals a dozen Paul's in this forum.
Old Aug 31, 2017 | 10:20 AM
  #36
hrhoward's Avatar
Click this: Paul Grant
Regular RTV is crap, imho. The Right Stuff is far better. Hell, I have even made crude o-rings with it before.
Old Aug 31, 2017 | 08:44 PM
  #37
ihscouts's Avatar
....or hit my signature up.
Old Aug 31, 2017 | 08:54 PM
  #38
Don't click anything down there, he's just trying for a date.......
Old Aug 31, 2017 | 10:54 PM
  #39
hrhoward's Avatar
Old Sep 1, 2017 | 06:46 AM
  #40
egebhardt's Avatar
Thanks. I sent Grant a message to his Gmail.
I greased the 6 zerks last night. Maybe that will help with some driveline clunk. I've yet to learn what is an acceptable amount and what is excessive. Then I need to learn where the play exists and determine feasibility of that whole possible project.
Until then, I ordered a Hi Lo Converter in an attempt to remove the aftermarket Sony stereo head-unit buzzing. It's the whine or buzz in the radio that increases in pitch as the alternator rotational speed increases.
