1998 Discovery Cruise Control not working
Old May 1, 2012 | 12:48 PM
nelsontod's Avatar
Default 1998 Discovery Cruise Control not working
The activator switch on the console does turn orange when i press it in, but, I then try to push "set" and nothing happens. Am I pushing the stupid button wrong or something? it pushed towards me... I looked to see if maybe it was the fuse, but the fuse for the cruise is also the fuse for other items that work just fine.
any thoughts are appreciated.
Than you.
Todd
Old May 1, 2012 | 03:09 PM
1998DiscoverySE's Avatar
Todd, the system runs off of an independent vacuum/hose system. It runs from the front drivers side of the engine compartment to the throttle, the ****ch on the steering column and a brake petal switch.
If there is a leak anywhere in there, i wont work. The vacuum is what holds the throttle, the steering column switch lets you engage it and the brake switch disengages. Also, if the vacuum pump is not providing suction, the system wont work even if all of the hoses are hooked up properly.
Old May 1, 2012 | 03:56 PM
nelsontod's Avatar
excellent, I will investigate and provide an update soon.
I have found the diagrams in the rave manual.
Thank you!
Old May 1, 2012 | 04:53 PM
nelsontod's Avatar
got it! totally cracked vacuum line that wasn't even connected to the vacuum pump.
Old May 1, 2012 | 08:09 PM
nelsontod's Avatar
ok, so I thought i had it, but after I replaced the cracked line it still does not work. I wonder if its the pump itself?
any thoughts?
Old May 1, 2012 | 09:01 PM
Keep checking for cracked line, thats the #1 problem.
Old May 1, 2012 | 09:22 PM
nelsontod's Avatar
ok, sounds good, i will do round 2 tomorrow!
Old May 1, 2012 | 11:53 PM
hh65flyer's Avatar
You have to 'push' set from the backside...or 'pull' towards the driver. At least that's how mine works on a 94 D1.
Old May 2, 2012 | 06:40 AM
jeff spahn's Avatar
What a retarded idea of a stand alone vacuum pump. The engine already makes vacuum, why introduce a new failure point?
Old May 2, 2012 | 06:46 AM
They went to the same school with SAAB engineers....
