1998 Land Rover Discovery I Engine Management Fuse #3 on Satellite 1 Keeps Blowing
So I go to bring the 1998 Disco I in to the garage to install my new master cylinder and the truck stalls...I check for spark and nothing. So I check my fuses and find that the interior fuse panel on satellite 1, fuse number three is blown. Now this is the engine management fuse. I replace, truck starts fine...I drive in to garage and continue the brake job.
Brakes work now...hooray.
Fuse blows again...put in new fuse...start truck...put in gear...fuse blows...put in new fuse...turn key fuse blows...keeps blowing now.
I am one match away from lighting this thing on fire and roasting marshmallows.
Any helpful hints before I dive in to the RAVE manual and spend some time I don't have finding the problem?
Anyone have the same problem and have a quick fix?
If I am reading this RAVE manual correctly, looks like that engine management fuse goes to the ECM, the fuel pump relay, and either the engine immobilization unit or the ignition control unit and multi-port fuel injection.
Any other redundancy's in this system that anyone knows of?
The 97 300TDi I am driving started this two days ago. I am still scratching my head, while I wait for the rain to clear to work on it again.
Has thecarfarm had any further progress or perhaps even success ?
You might start by looking around in the area you were working to see if perhaps you've pinched a wire underneath something...
Then start unplugging things that this fuse powers and hopefully you'll find your short..
I don't think much of the wiring on these things...
Good Luck
John
Good Luck
John
Unfortunately I wish I could offer you more info then I have.
It ended up being moisture that was blowing the fuse. The truck had been sitting through some pretty fierce rain storms and hot and cold days and there was some dampness inside.
Let the truck sit in the garage with the windows open for a couple days and it started fine and has not blown the fuse since.
Must have just been moisture in the right place to keep blowing that fuse.
No issues since.
best,
Jon
The Car Farm - Home
No issues since.
best,
Jon
The Car Farm - Home
The vehicle owner has since mentioned that it had stopped on him, twice, for no reason in the lead up to the service, prior to our trip. His mechanic had found nothing wrong. For these stops it did not blow fuses and just started fine after a small wait. This issue/symptom may be unrelated, but I mention it in case it is.
All,
So far it is repeatable. Happens far quicker [~ 5 seconds] when the diesel motor is warm. If I unplug the Glow Plug Controller it still happens. I have a quite a few fuses to go, if needed. I will look over the information that I have here about the electric circuit associated with, fuse 3 of satellite 1, to build a list of suspects for the next foray.
I did not set out to hijack this thread.
Cheers, Jim
Here's page from the RAVE electrical manual. Note that many modules to deal with diesel devilment can be involved. Like EGR, diesel immobilization, fuel shutoff, etc. If you have access to the RAVE, either a download or online (links below); you can look up the connector numbers and there are photos of the locations. You can divide and conquer.
If no meter available, one way to troubleshoot is attach a tail light bulb in series with the circuit. High draw of amps will light the bulb more brightly.
Thanks for that page, Savannah Buzz. I was muddling my way through the sections A4 & A5, of RAVE, making notes on the fuse's circuit flow. This page is much more simplified, and civilised.
Your other comments are noted, and appreciated. I am heading to the auto parts store tomorrow to get the bits to build up a fused fly lead, so I can test some items safely and in complete isolation from the rest of the wiring loom.
Cheers, Jim
Cheers, Jim
