1999 disco 1 project
Old Dec 17, 2011 | 04:07 PM
Danny Lee 97 Disco's Avatar
HH,
That is correct, the one on the transfer case is a round tin looking cover, the cover can be removed, I think there's like 4 corner screws holding the cover in place and the guts can be removed (coil) and that will disable the interlock function. It is designed to prevent inadvertent hi to low shifts. As designed, you are required to have the tranny in N to be able to shift the transfer case from high to low or vice versa. With the solenoid disabled, that function is as well. The actual problem is most likely the neutral safety switch (I think that is what it is called) or sloppiness in the tranny linkages that is failing to allow the solenoid to function properly.
It looks like a small tuna can sitting on the top rear portion of the transfer case top side.
Old Dec 17, 2011 | 04:13 PM
hh65flyer's Avatar
Thanks Danny Lee, I may look into that...
Old Dec 18, 2011 | 01:45 PM
HOSER's Avatar
The closest diagram I've found is from the Electrical Repair section of the D1 Manual. It shows an interlock solenoid, but of more interest to me- it almost appears the linkage from the shifter out to auto tranny is concentric cable?? I'm thinking my seized motion of shifter is in this area somewhere. What is the function of the interlock solenoid? I thought it to prevent CDL shifting when not in Neutral Trans. position. Could this solenoid be acting up on my auto.tranny shifter? I believe from the manual this is accessed from the top by removing the consul?? I think I've found evidence the sunroof was leaking right over top of the shifter, while the Disco was on hiatus- good chance this promoted the seized mechanism. Wise words are appreciated.
Attached Thumbnails 1999 disco 1 project-auto-tranny_0001.jpg   1999 disco 1 project-auto-tranny_0002.jpg
SinisterMoose
Jun 8, 2015 06:20 AM
Corrigan
Apr 26, 2013 02:38 PM
HOSER
Jan 1, 2012 10:27 PM
jafir
Apr 30, 2011 01:40 PM
Gallep
Oct 13, 2006 02:28 PM
