1999 Discovery I SD Reverse Gear Problem
Old Nov 14, 2014 | 01:06 AM
colemtd's Avatar
Originally Posted by fishEH
Every once in a blue moon I'll get in the truck to start it, turn the key, and get absolutely nothing. I'll jiggle the gear selector and it will fire right up. My situation is slightly different but my point is sometimes things can get a little sloppy and just being a 1/16th inch off can cause a prob.
Yeah I guess machines require precision, whether you are dealing with vehicles or computers, etc!!
Old Nov 14, 2014 | 01:09 AM
colemtd's Avatar
Originally Posted by Mark G
eventually ya learn the right way to jiggle the key ..to get it out. Then it becomes second nature till someone else gets in to drive it and can't figure it out..
LOL that is so true! I thought only mine had that problem!
Old Nov 14, 2014 | 07:13 AM
TOM R's Avatar
Originally Posted by colemtd
OK, I will check it out. My dipstick has 2 holes on it. So does one indicate low and one indicate full or how does it work?
Upper is full , you want it between the marks, iirc it should say on the stick?
Old Nov 14, 2014 | 10:29 PM
colemtd's Avatar
I'm not sure if it says that on the stick, I never noticed any writing on the stick just the 2 holes in there. I had the engine running but I don't think I had it in neutral when I last checked it.
I will check it in neutral with the engine running and see what it says..
Ozelote
LR2
Nov 14, 2011 04:05 PM
Livingintheskies
Jan 22, 2011 02:50 AM
dereklow
Defender
May 19, 2008 09:00 AM
cold_surfer
Mar 21, 2007 01:38 AM
db1047
Apr 27, 2006 08:10 PM
