4.2 in my disco
Old Feb 9, 2012 | 02:00 PM
ColoDisco's Avatar
Default 4.2 in my disco
Long time no talk!
Unfortunately I am on here due to a noise in my engine. I am getting a rather loud metallic noise inside my engine. Not entirely sure if it is the lifter or the piston making the noise but it is slowly getting worse. I have the option to get a 4.2 for free and I have learned that it will work in my 95.
What my question to you is, are there any unforeseen issues I am going to come across when installing the engine? IE mating it to the transmission, starter positioning, weird electrical connection issues, accessories which may not function properly?
Any insight is very welcome!
Old Feb 9, 2012 | 02:21 PM
jafir's Avatar
Should bolt right in, with lots more power.
Old Feb 9, 2012 | 02:29 PM
ColoDisco's Avatar
How about any maintenance that should be performed while it is out? It was rebuilt 70k miles ago however even after 70k miles I am sure a good solid service is in order.
Old Feb 9, 2012 | 03:25 PM
kenk's Avatar
As long as the 4.2 has a disributor set-up, which I believe they all were,it's a bolt-in.
BTW, are you positive the noise is internal engine? I had a cat converter on my '98 making a loud knock that I was positive was a rod knocking.
Old Feb 9, 2012 | 04:49 PM
ColoDisco's Avatar
No I am not sure. It could be something else however I am getting this new engine regardless since it is free. How did you find out it was the cat?
Old Feb 9, 2012 | 05:19 PM
Brad,
You are close, PM me your number and lets tank about the 4.2.
Old Feb 9, 2012 | 05:35 PM
atancreti's Avatar
Originally Posted by colodisco
i am getting this new engine regardless since it is free.
smart man!! Lol
Old Feb 9, 2012 | 09:26 PM
kenk's Avatar
I crawled under my truck when it was ideling to get a better listen, and was pretty sure it was coming from the drivers side cat. Took it to an exhaust shop, they confirmed and cut and welded in a new one. Noise gone.
Old Feb 11, 2012 | 07:23 PM
ColoDisco's Avatar
I will give that a shot Ken!
Old Feb 12, 2012 | 07:56 AM
Brad,
So what did you find out on your engine noise as well as the 4.2, did you get it?
