4.6 cam in 4.0
Old Oct 20, 2010 | 08:41 AM
Spencerfitch's Avatar
Default 4.6 cam in 4.0
What does it take other than the cam? Anything else?
Old Oct 20, 2010 | 08:47 AM
Long Haul's Avatar
New lifters also.
Old Oct 20, 2010 | 08:48 AM
okdiscoguy's Avatar
I would replace the lifters when you do it. Also inspect the pushrods closely for any wear. If your bearings are ok, should go right in... Don't think you have to swap springs.
I haven't done one, but Mike knows people who have. PM him and ask if he doesn't respond here. Post the results here if you do the swap.
Old Oct 20, 2010 | 09:05 AM
A 4.6 cam will make a nice improvement in your low end.
Old Oct 20, 2010 | 12:32 PM
Originally Posted by Long Haul
New lifters also.
New litters because there new or because the 4.6 is different?
Old Oct 20, 2010 | 12:43 PM
Long Haul's Avatar
Never use used lifters on a new cam or new lifters on a used cam.. Youll wipe the lobes right off the cam due to wear differences. You should always replace them together as a set. I wiped out too many cams trying to cut corners and save a dollar or two but it always come back to bite me later. The only exception is if you have roller lifters but these motors dont have them.
Old Oct 20, 2010 | 03:10 PM
kenk's Avatar
Do you use a cam out of an '03-'04 Disco or one for a p38 RR 4.6 with gems? Or either?
Old Oct 20, 2010 | 03:23 PM
tornado_735's Avatar
Hmm....I wonder what that could do to my old Rangie motor...
Old Oct 20, 2010 | 03:31 PM
Doesn't make any difference.
Old Oct 20, 2010 | 05:52 PM
Same engine, same cam, only difference is the engine management system, Bosch or GEMS, everything else is the same.
