4wd gear selector
Old Apr 23, 2014 | 06:48 AM
  #21
dipdgarage's Avatar
Will be putting shaft in the next few days. I'll update you guys!
Old Apr 23, 2014 | 08:50 PM
  #22
dipdgarage's Avatar
Well, I was able to put the driveshaft in. Do you guys have any recommendations on how to tighten down the bolts and nuts easily? It won't fit a socket and you can barely fit a wrench in there. The front of the driveshaft seems to be a 15 mm while the rear is a 14 mm. Thanks once again guys in advance!
Old Apr 24, 2014 | 06:48 AM
  #23
TOM R's Avatar
Nope just wrenches it sucks, get it in the right spot do 2 spin shaft do other 2 on each end
Old Apr 24, 2014 | 07:20 AM
  #24
dipdgarage's Avatar
For those that see this just leave transfer case on neutral and you should be able to spin assembly I believe. Thanks for the help guys! Hoping to get some mud on my little tank soon!!!
Old Apr 27, 2014 | 12:27 PM
  #25
dipdgarage's Avatar
Well, put the front drive shaft on and i still had some vibrations after 60. driving on the freeway yesterday vibration got really bad and my rear drive shaft flew off. so Now I must replace rear. I am hoping it was just old and came off? hoping once i put a new one I wont have any more problems.
Old Apr 27, 2014 | 02:54 PM
  #26
TOM R's Avatar
Fall off like the bolts came out or did the u joints let loose?
Old Apr 27, 2014 | 09:55 PM
  #27
dipdgarage's Avatar
Connection to transfer case
Connection to rear diff
Old Apr 28, 2014 | 07:35 AM
  #28
TOM R's Avatar
OK guessing you have a Rotoflex? Rubber thing in place of u joint
So is the drive shaft damaged?
If it just came apart guess you CA buy a rotoflex and throw it all back together, or switch to an all u joint drive shaft rotor was weak and driving with no front shaft killed it
Either way new u joint, new rotor before putting back in
  #29
TOM R's Avatar
Also looks like you need a diff seal
Old Apr 28, 2014 | 10:22 AM
  #30
dipdgarage's Avatar
I purchased a rear drive shaft with perfect rear u joint included. Same guy that sold me my front shaft. Hoping when I put this in it'll run well! I'm guessing it was old and u joints went bad w improper lubrication than shot to crap. The shaft is gone sitting on side of the road.
