4wd gear selector
Old Apr 28, 2014 | 10:27 AM
  #31
MM3846's Avatar
you bought a conversion yoke too right? bc you can bolt up a u joint anywhere on your rear axle...
Old Apr 28, 2014 | 11:01 AM
  #32
dipdgarage's Avatar
Pretty much got the shaft w u joint on one side and yoke w mount on the other side.
Old Apr 28, 2014 | 01:04 PM
  #33
TOM R's Avatar
It will not work you need the pinion yoke for the diff to replace the rotoflex one you have on the diff now
Old Apr 28, 2014 | 08:38 PM
  #34
dipdgarage's Avatar
Feel really dumb asking but what exactly do you mean? What's he difference of rotoflex and pinion yoke I need.
Old Apr 28, 2014 | 09:36 PM
  #35
TOM R's Avatar
The pic you showed of the diff is 3 bolt for a piece of rubber used in place of u joint on some years
If the replacement shaft has u joints on both ends you will need a u joint type yoke for the diff
I will also recommend you check the fluid level in rears and transfer case
Old Apr 28, 2014 | 10:08 PM
  #36
dipdgarage's Avatar
I just did the fluid change on both diffs and transfer case.
Old Apr 28, 2014 | 10:09 PM
  #37
dipdgarage's Avatar
Land Rover Discovery 1 Rear Driveshaft w U Joints Drive Shaft 95 96 97 98 99 | eBay
this is the one i bought.
Old Apr 29, 2014 | 07:27 AM
  #38
TOM R's Avatar
This is what used to be on the diff end
Land Rover Discovery 1 Rotoflex Rear Driveshaft Coupling 94 95 96 97 98 99 | eBay
You need a u joint flange for diff to use with the shaft you bought, he states for use in a rotoflex d1 you need the flange
Old Apr 29, 2014 | 07:29 AM
  #39
TOM R's Avatar
This is the correct drive shaft look at the right side
http://www.ebay.com/itm/land-Rover-D...98785266&rt=nc
Old Apr 29, 2014 | 07:35 AM
  #40
TOM R's Avatar
You will need this
Land Range Rover Classic Discovery Defender Differential Driveshaft Flange Kit | eBay
You need to be sure all these u joints are good or replace them on the drive shafts you are installing or end up back where you started
