4WD issues
Old Dec 23, 2012 | 02:06 PM
Ron6977's Avatar
Default 4WD issues
Hey guys ive got a question. I jacked up my D1 to look for some noise issues and i realized the when i spin one of my tires they both spin. Is that right??? or does that mean my 4WD is engaged.
Ive had issues with the truck feeling like it was in 4WD.
Old Dec 23, 2012 | 02:20 PM
fishEH's Avatar
I assume we're talking about two wheels on the same axle? Do they spin opposite directions? They should. They should only spin the same direction if you have a rear differential locker and its engaged. Lockers didn't come stock on a truck.
Old Dec 23, 2012 | 02:56 PM
Ron6977's Avatar
Opps im sorry, its the front wheels, and they are spinning in the opposite directions
Old Dec 23, 2012 | 04:36 PM
tooltech's Avatar
Yes that's normal..
Old Dec 23, 2012 | 06:06 PM
Ron6977's Avatar
Ahhhh good, thank you. Now i gotta figure out whats grinding on one side. havent pulled the wheel off yet.
Old Dec 23, 2012 | 06:29 PM
mossmanxjt's Avatar
A Disco is always in 4WD you do not have an option to disengage it.
Old Dec 23, 2012 | 10:14 PM
fishEH's Avatar
The grinding could just be brakes.
Old Dec 24, 2012 | 05:13 AM
tooltech's Avatar
The grinding could also be a busted bearing... at least that's what was causing the grinding on mine.
Pulled the hub off and all the bearings just fell out. Good luck with yours =)
tracengrant
Feb 24, 2007 09:25 PM
senorris08
Jan 8, 2007 02:34 AM
Doak
Oct 15, 2006 08:14 PM
dogstarsix75
Apr 23, 2005 11:21 AM
