5 speed tranny noise
Old Jul 10, 2010 | 08:43 AM
Silver_Slug's Avatar
Default 5 speed tranny noise
I just picked up my POS disco yesterday and when i shift from 3rd to 4th there is a small click noise and when i down shift from 5th to 4th it grinds. Clutch going or is it syncros?
Old Jul 10, 2010 | 09:41 AM
AK Rover's Avatar
If it was the clutch it would effect all the gears. Since it sounds like the problem is limited to 4th gear I would think the syncro is a more likely candidate. Of course I think the syncro failing would effect all the gears also. When was the last time the tranny was serviced?
Old Jul 10, 2010 | 10:13 AM
i have no idea. ill probably give it some lovin. i got this thing for 1500 so i think i need to do a once over on it all. might do clutch and sycros because it will be easier if the tranny is dropped.
Old Jul 10, 2010 | 02:09 PM
AK Rover's Avatar
Since you just got the truck it's a good time to go through the 60K service.
Old Jul 10, 2010 | 03:13 PM
antichrist's Avatar
Many people use ATF in the R380 (assuming that's what you have) because that's what the manual calls for, but Rover released a TSB saying to use MTF.
Redline MTL is the lube of choice for most people in them.
Danny Lee 97 Disco
ROAMING WITH FRIENDS
Aug 26, 2012 06:23 PM
Silver_Slug
Jul 15, 2010 07:46 AM
msk2503
Nov 19, 2008 07:38 AM
SICSOLX
Nov 12, 2007 12:21 PM
soupdogg
Sep 25, 2007 12:49 PM
