Driveline Noise @ Highway Speed, help!
Old Nov 11, 2007 | 06:08 PM
SICSOLX's Avatar
4wd High
Default Driveline Noise @ Highway Speed, help!
Next issue that I am working on is a noise and vibration that my 2000 Disco II(185k) produces when making sweeping left hand turns @ highway speeds (65-75 mph). The noise and vibration is similar to driving over the rumble strips on the highway, but not as severe. This only happens when turning left. Nothing when vehicle is moving in a straight line or turning to the right. Any suggestions? The noise and vibration seem to be coming from the right front. The vehicle has ACE.
Old Nov 11, 2007 | 07:37 PM
Default RE: Driveline Noise @ Highway Speed, help!
Better check your left CV joint on the front axle, sound like it is about gone. With your mileage, you should replace both.
Old Nov 12, 2007 | 11:12 AM
SICSOLX's Avatar
4wd High
Hey Mike,
Thanks for the quick reply. Just curious why you think that the problem is the left CV joint. The noise seems to be coming from the right front. I checked the left front suspension and the CV boot is wet, not sure if it is torn or if the axel seal is bad. Any chance that the noise could be a faulty wheel bearing? What should I look for when doing my tear down? Thanks again!
Old Nov 12, 2007 | 12:21 PM
ajh's Avatar
ajh
If you wheel look at Ashcroft heavy-duty front CV's.
WaltNYC
May 6, 2015 09:15 AM
CaptainCulp
Aug 24, 2013 03:17 PM
open range
May 16, 2008 06:09 PM
soupdogg
Sep 25, 2007 12:49 PM
Disco_Drew
Jul 27, 2007 05:20 AM
