94 disco 1 no start after flood.
Well long story short I got stuck offroad in a rut. Then the rain come and now my truck won't start. It has fuel and it has spark... What else should I look at or dry out. Passenger side had water up to the side pocket. Just to reiterate truck cranks strong but does not start. I verified fuel and spark already. May do a compression check later just to check.
Thanks
David
Thanks
David
Ok... No plastic box... Fuse box that's about it. The water line is up to the bottom relays behind the passenger kick panel. Where is the ecu?
Edit: found found the location. Looking at the water line the ecu should be fine tho there is water up there on the inner fender. I imagine it just rolled in from the hood area. Do I pull the ecu to dry or hair dryer?
disconnect battery, unbolt and unplug, carefully open it to see if it is wet inside, not sure I would want to apply any heat source to dry it, you could have soaked a couple of sensor plugs or the relays behind that pass side kick pannel
Because there's spark at the cap and rotor. While I didn't test all of them I did test a few and they had power. The injectors are letting in fuel because there's a strong odor of gas after a few failed starts. May have fouled the plugs while it was in the water. My thinking is, fuel and spark = start no matter what the computer thinks.
