94 Disco Cranks But Won't Idle, Rev.
Old Oct 30, 2012 | 09:34 PM
wabuson's Avatar
Default 94 Disco Cranks But Won't Idle, Rev.
Gotta get to work so I'll make this quick. I can add any info as needed from work.
Took my 94 Disco 143K to the grocery store and when I got back in it wouldn't turn over. Cranked and it seemed like it might be out of gas. Needle at 1/5th tank so I rolled it into the gas station next door and put $20 in. Same problem.
When I turn the key it cranks fine and most of the time you can tell it fires a couple times before dying. Gas pedal is fine, checked the line to the engine, but I get no rev when I step on it right after i feel it fire a couple times. All in all it stays idle for maybe 5 seconds before stalling.
Does this sound familiar to anyone? Fuel pump issue? I'd like to try and troubleshoot it myself obviously before I take it in. I've got the RAVE and was going to go threw that tomorrow durring daylight but i wanted to get a head start here first.
Much Appreciated.
Old Oct 30, 2012 | 09:42 PM
Sounds like a bad fuel pump.
Wont know for sure until you check the fuel pressure.
Continually running the gas tank that empty will shorten the life of the fuel pump.
The pump is submerged in the gas, the gas keeps the pump cool, electric motors dont like excessive heat.
Rent a fuel pressure tester, on the passenger side of the engine, on the fuel rail is a schrader valve, check the fuel pressure there, you need in the mid 30's.
Old Nov 1, 2012 | 07:01 PM
wabuson's Avatar
So i hooked up it up turned the key to 2 and there is no pressure. Zilch. 0. Next step is to replace Fuel Pump?
Old Nov 1, 2012 | 07:10 PM
Replace the fuel filter first.
Then if still not fuel pressure check for power at the fuel pump.
If no power replace the fuel pump relay.
If power but no pump working replace the fuel pump.
Its a cheap easy job on your truck.
Old Nov 1, 2012 | 07:24 PM
wabuson's Avatar
I really appreciate it, thanks.
jrkstore43
Sep 28, 2012 04:16 PM
pinkytoe69
Feb 26, 2012 06:20 AM
discoandrew
Oct 12, 2011 05:13 AM
texmanmoore
Dec 5, 2010 12:45 PM
jennina1
Aug 15, 2009 09:45 AM
