95 Disco 1 Rear A/C
discovery with rear air do need more R134a than those without. It also could be something like the rear expansion valve is bad, causing high head pressure when you turn it on... I'm just guessing, because I never really had too many problems with the rear air on my 96. Also, it's going to make the entire system work harder. Are you condenser fans coming on when you turn the air on? You'll probably need to hook some gauges up to it and see what it's doing when it's not working right.
bcolins
06-22-2013 08:55 PM
hilltoppersx
12-22-2010 05:15 PM
