rear quarter panel and rear window seals
Old May 22, 2008 | 12:12 AM
ljdiscovery's Avatar
Default rear quarter panel and rear window seals
The seals on both of my rear quarter panel windows as well as the rear cargo door window have some unsightly cracks, mainly at the corners. Anybody have these problems? Couple of questions, 1. where is the best place to buy some new seals, 2. what is the cost of the seals, 3. what is the cost for install? (no leaks just looks crummy).Is using black silicone tofill the cracks an option? Thanks Phil
Old May 22, 2008 | 08:59 AM
Default RE: rear quarter panel and rear window seals
Call Rover and find out, we are not a parts store.
Then call around and get some quotes from a couple local body shps or auto window shops.
Old May 22, 2008 | 10:30 AM
Phototone's Avatar
ORIGINAL: ljdiscovery
The seals on both of my rear quarter panel windows as well as the rear cargo door window have some unsightly cracks, mainly at the corners. Anybody have these problems? Couple of questions, 1. where is the best place to buy some new seals, 2. what is the cost of the seals, 3. what is the cost for install? (no leaks just looks crummy). Is using black silicone to fill the cracks an option? Thanks Phil
A number of on-line vendors have the window seals. Any local car-glass installation shop can install them for you. You will have to get a quote from whatever glass shop you decide to use. You may have to get the seals yourself, though. They are not available thru the normal vendors the car glass shops use.
ngarover
May 12, 2021 09:00 AM
mark.ferdinand@gmail.com
May 11, 2021 10:36 AM
FloridaDiscoII
Sep 5, 2012 06:22 PM
jpluncford21
Oct 17, 2011 09:45 AM
mdisalvo55
Feb 3, 2008 07:44 PM
