95 disco - seating new injectors?
Old Aug 19, 2013 | 10:21 AM
antichrist's Avatar
Originally Posted by tylor36
I later found out that there needs to be a flat rubber washer inside the rail and then an o-ring on each end of the injector.
Land Rover lists no such part. Sounds like something someone added for some reason
Old Aug 19, 2013 | 01:25 PM
tylor36's Avatar
The flat rubber washers came with my headgasket kit for a 95' from Atlantic British. I assumed thats where they went because before i put them in the drivers side shot fuel out like crazy.
Is there supposed to be one or two o-rings at the top where the injector meets the rail? When I used one it shot out fuel, when I put that rubber flat washer in the rail and then the injector with o-ring, it stopped the leaks?
EDIT*
It came in this set, http://www.roverparts.com/Parts/STC4082HBK.cfm
Old Aug 19, 2013 | 11:14 PM
mmaesner's Avatar
Tylor I think if there is room to put a flat washer above the injector then you are not seating them all the way in, I just re-did mine with napa o-rings part #2-12093 and in order to get the retaining clip on in the lowest groove on the injector I had to really seat the injectors down snug to the bottom of the cup, it definatly worked better to put the injectors into the rail firswt then into the manifold. So now no leaks but still the random hard start.
disco-parts
Mar 25, 2012 01:18 PM
Dan_da_LR3_H2_man
Nov 1, 2008 10:17 PM
4banger77
Aug 3, 2008 02:37 PM
Young
Jun 29, 2008 02:48 PM
nwoods
Nov 16, 2005 12:14 AM
