96 SD Drag Link Rubber split on ball joint?
Old 04-03-2012 | 11:29 AM
KRMusher's Avatar
7th Gear
Default 96 SD Drag Link Rubber split on ball joint?
New to this drag link part. What does a split rubber on the ball joint imply? Does it need replacing? It's on passenger side close to swivel pin.
If replace where is a good source? New, used?
Thanks for all comments.
KRMusher
Old 04-03-2012 | 11:42 AM
Jake1996D1's Avatar
KRMusher
Yes it needs replacing. Water and dirt will get in there and rust/destroy the ball joint in no time. I prefer the greseable joints, as long as you grease them they will last a long time. I just hit them when I grease my drive shafts at regular (maybe obsessive) intervals.
Old 04-03-2012 | 09:43 PM
hilltoppersx's Avatar
pick up the terrafirma tie rod, track rod and damper from Lucky 8 they have greaseable joints and are twice as thick as the stock ones.
mln01
11-08-2011 06:51 AM
malmberg
08-09-2009 07:57 PM
bmwrovers
06-04-2009 06:17 PM
Disco Alan
05-13-2009 12:34 PM
Disco2Guy
07-19-2008 02:23 AM
Quick Reply: 96 SD Drag Link Rubber split on ball joint?
