96 SD Drag Link Rubber split on ball joint?
Old Apr 3, 2012 | 11:29 AM
KRMusher's Avatar
7th Gear
Default 96 SD Drag Link Rubber split on ball joint?
New to this drag link part. What does a split rubber on the ball joint imply? Does it need replacing? It's on passenger side close to swivel pin.
If replace where is a good source? New, used?
Thanks for all comments.
KRMusher
Old Apr 3, 2012 | 11:42 AM
Jake1996D1's Avatar
KRMusher
Yes it needs replacing. Water and dirt will get in there and rust/destroy the ball joint in no time. I prefer the greseable joints, as long as you grease them they will last a long time. I just hit them when I grease my drive shafts at regular (maybe obsessive) intervals.
Old Apr 3, 2012 | 09:43 PM
hilltoppersx's Avatar
pick up the terrafirma tie rod, track rod and damper from Lucky 8 they have greaseable joints and are twice as thick as the stock ones.
mln01
Nov 8, 2011 06:51 AM
malmberg
Aug 9, 2009 07:57 PM
bmwrovers
Jun 4, 2009 06:17 PM
Disco Alan
May 13, 2009 12:34 PM
Disco2Guy
Jul 19, 2008 02:23 AM
