97 Disco Finally Started! But then smokes and dies...
Well, since you didn't use RTV to seal the intakes coolant ports if it where my project that's what I'd be doing right now. It's such a common failure point old or new. Common practice, store that in your memory bank. Seal the intake coolant ports.
You can remove the whole intake system as one unit. It saves allot of time. I've done it on many vehicles including my Brit wonders. With that being said you don't have much to loose to give it a shot.
Another check I would be doing is a compression test. That rules out which cylinder is the failed one or rules out nothing is wrong with the head gasket at all.
Front cover. Did you seal the pump/front cover around those coolant ports? That's gasket AND sealant.
As I recall, the majority of writeups that I have read usually apply sealant to one side of most gaskets. I would like to see something definitive about what to apply where and which gaskets should have no sealant like the exhaust gaskets typically have none.
That might help a lot of us who know a little about a lot but maybe not enough on any one thing like that.
Rule that out. Just picking your brain for things that could happen as I personally tend to fly through everything like a bull in china shop. It's a been there done that sort of reality for me......
I'm working on a BBB complaint, so my head is in two places right now.
Compression test.....rule that head gasket out.
Yes gaskets are confusing to me. There are so many kinds of gaskets, RTV, sealants, applications, techniques, and possible combinations. I've found no guide that describes the best way to use them for the best seal. For this project I've used RTV ultra black on both sides of front cover, water pump, plenum heater, and sump gaskets.
Could a compression test show good compression cold and bad with a warmer engine?
