97 Disco HG Repair
Old Oct 11, 2011 | 01:41 PM
  #131
psykokid's Avatar
any word from the place doing your heads? curious to see how much they are going to charge as they were pretty sludged up..
Old Oct 11, 2011 | 03:07 PM
  #132
Danny Lee 97 Disco's Avatar
Originally Posted by EricTyrrell
Just had the radiator quoted for a rodding out. 150$ for one side, 250 for both. Beats 500+ for a new one though.
I would get more quotes from other shops, that one sounds really high compared to what others have reported on here. Try to find either a place that does work on large trucks and farm equipment or a small independent shop that has been around a long time for a more reasonable price.
Also be sure the separate cooler lines are clear.
Old Oct 11, 2011 | 04:40 PM
  #133
EricTyrrell's Avatar
Both shops I talked to are independent and have been around a long time so I'm not sure where else would be cheaper. One guy was $5 cheaper
The guy I worked with was very helpful though, even if his quote was high. In the end he pressure washed it, pressure tested it, flushed and flow tested it, and blew it out with compressed air for $29. He said it was in good condition and wasn't in dire need of a rodding, so I decided to take it home.
Now that it's clean I'll either keep it, or try to sell it and get a new shiny one
Old Oct 11, 2011 | 06:32 PM
  #134
Save your money on the new one at this point. This one may do just fine, if flow test was OK. You unit has a tranny cooler (driver side) and oil cooler (battery side). Be sure both of those pass air through with no problem, a restricted oil cooler is an engine killer. If you have the plastic plug in the top, remove it and replace with a brass one (order on line to keep from using plain old NPT, it is a little different). Shine light inside and look and ends of the few radiator tubes (horizontal) that you can see, if not crusty is a good sign.
You have a lot more things that need attention before radiator, and it is a piece of cake.
Old Oct 11, 2011 | 09:44 PM
  #135
Yeah if it test good, should be fine.
Mine has a separate transmission cooler that is a small unit up front behind the grille. It is not part of the radiator. I did have to replace one of the lines on it when I first got it due toa pinhole leak that sprayed into the front driver's side wheel well and had me looking for a power steering leak until I got underneath with a good light with it running. You could see the spray coming from the pinhole near the metal end.
Don't they all have that?
Old Oct 11, 2011 | 11:47 PM
  #136
Mine has the same setup you described.
Old Oct 12, 2011 | 04:43 AM
  #137
Look again at this drawing from RAVE, mine had tranny cooler in rad AND small cooler in front, that's where two lines at bottom of this drawing go to.
File Type: pdf
Old Oct 12, 2011 | 01:10 PM
  #138
Thanks for the clarification.
Old Dec 10, 2011 | 09:32 AM
  #139
dparham's Avatar
Nice Post!
Old Dec 10, 2011 | 11:00 AM
  #140
hh65flyer's Avatar
Seems really high on the rad work as I just had this done on mine and it was $90. I don't know what the difference is or the requirement for removing both tanks though. Plus there are likely more EPA tarrifs in OR than MT.
Sounds like you don't need this work done anyway...
